[Proj] Compilation on AIX64
Frank Warmerdam
warmerdam at pobox.com
Thu Jul 11 11:24:44 PDT 2013
Netr,
If you want to use a different compiler the usual practice is to do
something like:
export CC="gcc -maix64"
./configure
make
I don't know an particulars about your system or AIX specific issues, but
if you have a followup email on this problem you are more likely to get
asistance if you include the resulting link command in the build and the
error produced.
Best regards,
Frank
On Thu, Jul 11, 2013 at 11:00 AM, netr <netr at caramail.com> wrote:
> Hello,
> First, please excuse my english, I didn't practice for a long time.
> I'm currently developing a component using the libproj.a on AIX. But it
> doesn't link the libproj.a that I previously generate on the same
> environement.
> For my component I use "gcc -maix64" to compile, but, to obtain the
> libproj.a, I followed the instruction and used the makefile autogenerated
> by
> proj4. However, it used "gcc". So, I changed, the token CC=gcc -maix64 in
> the makfile, but I still have an issuein the liking.
> Do you have any idea, I'm lost...indeed, I'm a JAVA developper not a C
> expert ;-)
> Thanks by advance for any help.
> http://osgeo-org.1560.x6.nabble.com/Compilation-on-AIX64-tp5065849.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130711/21a04132/attachment.html>
More information about the Proj
