[Proj] [osgeo4w-dev] Using cmake of osgeo projects?
Greg Troxel gdt at ir.bbn.com
Thu Jul 25 17:01:37 PDT 2013
Charles Karney <charles.karney at sri.com> writes:
> On 06/29/2013 09:05 PM, Mateusz Loskot wrote:
>> I don't know what's typical, regarding developer's reaction on CMake adoption
>> proposal, but as a big fan of CMake, I wouldn't paint it in pink colours only.
>> Thus, I understand, for example, Frank's experience may be very different.
>> Finally, if a software has a build system that is usable and works on
>> all supported
>> platforms, I also understand a team may go for lean approach: don't change it.
> I basically agree.  However, let's not forget those users who need, for
> one reason or another, to compile these packages themselves.
I find it odd to talk about how one can't compiile packages oneself when
they use autoconf.
Is this really about accomodating windows without using cygwin?  I have
found that autoconf/automake/libtool is really quite workable.
Does cmake support
   building in an objdir, with a read-only srcdir
   cross-compiling
   the equivalent of 'make dist' and 'make distcheck'
   building on a system not previously known to the build system, as
   long as feature tests are doable
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130725/d0c496b3/attachment.sig>
