[Proj] So close -- Lat / Long to Pennsylvania State Plane North NAD27
Jeremy Boecker jeremy.boecker at gmail.com
Fri Jul 26 11:50:02 PDT 2013
Thank you, I tried what you said, and what I'm getting as output is as
follows when I run the same batch file:
WGS84-NAD27
*       * 0.000
WGS84-NAD27PAft
*       * 0.000
NAD27-NAD27PAft
2502332.66      416669.38 0.000
I'm thinking my EPSG definitions might be messed up somehow... but I also
tried copying from spatialreference.org, and still I get the same output.
(It seems like the 4326 EPSG is not working... )  Any further ideas? Your
second result is the correct and expected conversion result... not sure why
I'm getting asterisks and zeros for the same command! :/ Thanks again for
your help!!
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130726/e0a420f4/attachment.html>
