[Proj] Search directory for grid shift files
Thu Nov 7 08:33:43 PST 2013
On Thu, Nov 7, 2013 at 8:22 AM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
>  Hi Frank
> Thank you for the advice. The PROJ_LIB variable seems to be set at least
> on windows, so that's already a good thing to check.
> >One suggestion, in the QGIS context might be that you keep them in some
> sort of QGIS subtree, and use pj_set_searchpath() to check there
> Does the pj_set_searchpath add an additional search path or does it also
> override the default path? If it adds, having a dedicated subdirectory
> sounds good.
Marco,
It actually replaces the search path, but in normal operation the "search
path" is the last thing checked, after all the other rules (ie. PROJ_LIB,
install location, custom pj_finder, etc) have been exhausted.  So calling
it within QGIS won't do any harm since nothing else will have set a search
path.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131107/40d51c8b/attachment.html>
