[Proj] Transformation of rotation
support.mn at elisanet.fi support.mn at elisanet.fi
Wed Sep 4 07:23:48 PDT 2013
Hello,
use 7 parameter datum shift - that include rotational parameters for each axis
in proj.4 you use towgs84 statement to define any datum shift.
see also:
http://en.wikipedia.org/wiki/Helmert_transformation
Janne.
Filip Arlet [filip89 at seznam.cz] kirjoitti:
> Hi I want to transform rotation in XY (one angle) from one coordinate system
> to another (JTSK -> WGS84). I'm want to transform text, defined by origin,
> scale and rotation (angle around z axis). Transfrom scale from one system to
> another is not a problem, but how can I transform rotation. I know that
> transformation includes different projections, so its not going to be
> accurate (i would have to transform text definitions too). But partial
> solution is fine.
> Filip
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
