[Proj] possible bug in proj.exe 4.8.0 under Windows with -V
Mikhail Tchernychev
misha at mail.geometrics.com
Fri Apr 25 16:07:50 PDT 2014
Hi, Just wanted to let you know that it appeared to be a problem with -V
under windows.
Here is sample session:
C:\Windows\System32>proj +proj=tmerc +lon_0=-75 +ellps=clrk66 -V
+k_0=0.9996
#Transverse Mercator
# Cyl, Sph&Ell
# +proj=tmerc +lon_0=-75 +ellps=clrk66 +k_0=0.9996
#Final Earth figure: ellipsoid
# Major axis (a): 6378206.400
# 1/flattening: 294.978698
# squared eccentricity: 0.006768657997
-75.5 40.5
Rel. 4.8.0, 6 March 2012
<proj>: while processing file: <stdin>, line 1
Unknown error
The same sequence works fine under Linux.
I hope it helps,
Mikhail
PLEASE NOTE: This message, including any attachments, may include privileged,
confidential and/or inside information. Any dissemination, distribution or copy
of this communication by anyone other than the intended recipient is strictly
prohibited. If you are not the intended recipient, please notify the sender by
replying to this message and then delete it from your system. Information
provided via electronic media is not guaranteed against defects including
translation and transmission errors. The company accepts no liability for any
damage caused by any virus transmitted by this email.
Geometrics Inc. | 2190 Fortune Drive | San Jose, CA 95131 USA
More information about the Proj
