[Proj] The area of a rhumb line polygon
Charles Karney
charles.karney at sri.com
Tue Dec 16 06:13:23 PST 2014
Only the toolbox version requires R2014b. The Matlab release I used was
R2013a and it works with Octave too. Just click on "Download Zip".
GeographicLib already works with the World Magnetic Model 2015. You can
download the model from
https://sf.net/projects/geographiclib/files/magnetic-distrib/
and you are good to go. Just specify "-n wmm2015" to the MagneticField
utility. (This will be the default for GeographicLib 1.40 which I will
be releasing later this week.)
While on the subject of great ellipses, I provide a critique of some
papers which advocate great ellipses for the purposes of navigation at
http://geographiclib.sf.net/html/greatellipse.html#gevsgeodesic
--Charles
On 2014-12-16 09:01, Noel Zinn (cc) wrote:
> Thanks for the Matlab versions, Charles. Why R2014b? (I'm still running
> R2014a, but planning an upgrade to R2015a, which will include the new World
> Magnetic Model.)
> Noel
> Noel Zinn, Principal, Hydrometronics LLC
> +1-832-539-1472 (office), +1-281-221-0051 (cell)
> noel.zinn at hydrometronics.com (email)
> http://www.hydrometronics.com (website)
> -----Original Message-----
> From: Charles Karney
> Sent: Tuesday, December 16, 2014 7:14 AM
> To: PROJ.4 and general Projections Discussions
> Subject: [Proj] The area of a rhumb line polygon
> The calculation of the area of a geodesic polygon has been included in
> GeographicLib since v1.4 (2010-09).
> In the latest version v1.39, I've also included the equivalent
> calculation when the edges of the polygon are rhumb lines. The
> formulation is given in
> http://geographiclib.sf.net/html/rhumb.html#rhumbarea
> and the online planimeter
> http://geographiclib.sf.net/cgi-bin/Planimeter
> implements this area calculation. I've also worked out the area when
> the edges are great ellipses. For the formulation, see
> http://geographiclib.sf.net/html/greatellipse.html#gearea
> An implementation is included in the Matlab package
> http://www.mathworks.com/matlabcentral/fileexchange/47898
> Comments are welcome.
> --Charles
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Charles Karney <charles.karney at sri.com>
SRI International, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Proj
