[Proj] 4.9.0 Beta2 Available
Chris Crook ccrook at linz.govt.nz
Tue Feb 4 18:05:53 PST 2014
Absolutely correct on both counts - not sure how the #else/ got compiled at all.
Thanks
Chris
> -----Original Message-----
> From: Charles Karney [mailto:charles.karney at sri.com]
> Sent: Wednesday, 5 February 2014 12:39 a.m.
> To: proj at lists.maptools.org; Chris Crook
> Subject: Re: [Proj] 4.9.0 Beta2 Available
> On 02/03/2014 11:53 PM, Chris Crook wrote:
> > I think that the bug relating to NTv2 hasn't been implemented into
> > this release yet... this is a significant problem for implementing
> > multilevel NTv2 grids - basically it doesn't work.  This is a long
> > standing bug - there is a patch file provided in
> > http://trac.osgeo.org/proj/attachment/ticket/177/0001-Fixing-NTv2-nest
> > ed-grid-issues.patch
> > It would be great if this could be resolved at last.
> In the patch, line 44 of pj_gridinfo.c becomes
>    #else/
> presumably that's supposed to be
>    #else
> Also the comment before the function pj_gridinfo_parent incorrectly
> identifies the function as pj_gridinfo_init_ntv2.
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
