[Proj] gdalwarp EPSG:32662 problem
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 7 22:11:42 PST 2014
Sorry for cross posting. This seems like a proj4 issue but might be gdal
related.
I've run into a problem that I think is related to a change in the EPSG
definition for EPSG:32662
The symptom is that the image after gdalwarp reprojection is about 20km
south of where it should be.
old system is correctly aligned:
GDAL 1.4.2.0, released 2007/06/27
proj Rel. 4.5.0, 22 Oct 2006
# WGS 84 / Plate Carree
<32662> +proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84
+datum=WGS84 +units=m +no_defs <>
new system is shifted about 20km south:
GDAL 1.9.2, released 2012/10/08
proj Rel. 4.8.0, 6 March 2012
# WGS 84 / Plate Carree (deprecated)
<32662> +proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84
http://spatialreference.org/ref/epsg/32662/
This indicates that the definition in proj 4.8.0 is wrong. Would the
+ellps=WGS84 account for this shift?
Any thoughts on this?
Thanks,
-Steve
More information about the Proj
