[Proj] Have LCC center terms, need PROJ.4 terms
Andre Joost
andre+joost at nurfuerspam.de
Wed Feb 12 12:55:40 PST 2014
Am 12.02.2014 00:33, schrieb Hamish:
> http://muck.otago.ac.nz/~hamish/sbss/xlat.txt.bz2
> http://muck.otago.ac.nz/~hamish/sbss/xlong.txt.bz2
I checked it the other way round:
Changed the header of your files to:
> nrows 138
> ncols 138
> xllcorner 0
> yllcorner 0
> cellsize 12000
> NODATA_value -32768
which makes them readable for the GDAL AAIGrid importer.
Then created contour lines from the data, and overlayed it with a WGS84
grid.
The custom projection I came best with was
+proj=lcc +lat_1=39.338 +lat_0=39.338 +lon_0=-84 +k_0=1 +x_0=233925
+y_0=722000 +a=6371229 +b=6371229 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
the x_0 value was easy to get, just the distance between left margin and
the 84° meridian. For y_0, I measured the difference between WGS84 grid
and the countour lines grid. So, empirical too, but I think you can not
get much better from a 138x138 cell grid at that resolution.
Overlaying in QGIS I got this picture:
<http://home.arcor.de/andre.joost/WRF-LCC.png>
The cell values around the map center read (from line 75 and 76):
lon: -77.068146/ -77.057312 / -76.927246 /-76.916199
lat: 40.32201 / 40.313641 / 40.214413 / 40.206055
So CEN_LAT and CEN_LON are just the average of the four middle cells,
and have nothing to do with the following projection parameters.
Just some more references on the WRF projection parameters:
http://mailman.ucar.edu/pipermail/wrf-users/2007/000698.html
http://www.mmm.ucar.edu/wrf/users/docs/user_guide/users_guide_chap3.html
HTH,
André Joost
More information about the Proj
