[Proj] Mingw JNI build issue
Mark Christy
mchristyuk at hotmail.com
Wed Feb 26 11:04:21 PST 2014
HI Mike,
I had to change something in a couple of the source files as there were compilation errors, but nothing that would stop it working with Android.
Apologies, it's a bit hazy as it was a while since I got it compiling!
The biggest issue was with the VC build script.. but that was mainly just to add the JNI portion to it.
I'll zip up the entire build folder and upload it for you in the morning.
Cheers
Mark
> Date: Wed, 26 Feb 2014 10:46:35 -0800
> From: mike.reynolds at aug-tech.co.uk
> To: proj at lists.maptools.org
> Subject: Re: [Proj] Mingw JNI build issue
> Hi Mark,
> Example files would be great!
> I've just got the code into VC Express, but its implying I have to change
> the JNI wrapper functions to use C++ versions, which I'm loathed to do as I
> use the same wrappers on Android.
> Cheers.
> Mike
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mingw-JNI-build-issue-tp5093816p5106192.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140226/a887152c/attachment.html>
More information about the Proj
