[Proj] Mingw JNI build issue
Mark Christy
mchristyuk at hotmail.com
Thu Feb 27 00:40:13 PST 2014
Oh yeah.. and I built it from the command line using the instructions given in the readme.txt file for building with VC++.. I didn't use the GUI interface...
Cheers
Mark
> Date: Wed, 26 Feb 2014 10:46:35 -0800
> From: mike.reynolds at aug-tech.co.uk
> To: proj at lists.maptools.org
> Subject: Re: [Proj] Mingw JNI build issue
> Hi Mark,
> Example files would be great!
> I've just got the code into VC Express, but its implying I have to change
> the JNI wrapper functions to use C++ versions, which I'm loathed to do as I
> use the same wrappers on Android.
> Cheers.
> Mike
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mingw-JNI-build-issue-tp5093816p5106192.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140227/28a1c93d/attachment.html>
More information about the Proj
