[Proj] Info on proj4 formulas
Charles Karney
charles.karney at sri.com
Fri May 9 10:44:14 PDT 2014
The JHS formulas (extended to 6th order) are proj.4's etmerc projection
(e = "extended"). The 4th-order series in JHS were first given by
Krueger in 1912. The same formulas (at 6th order) are now recommended
by NGA for UTM (see my posting of 2014-04-29).
--Charles
On 2014-05-09 13:36, Antti Castrén wrote:
> Hi,
> It seems that they differ at least on Transverse Mercator. OGP
> Guidance currently recommends so called JHS formulas which are
> satisfactory within +/-40 degrees from central meridian compared to
> Snyder's +/-4 degrees. Snyder's formulas seem to be coded in proj.4
> PJ_tmerc if I have read the current version correctly.
> For more information read OGP document pages 48...53
> Cheers,
> Antti
> FYI: The so called JHS formulas were actually created by prof R A
> Hirvonen and published (in Finnish) already back in 1972.
> http://en.wikipedia.org/wiki/Reino_Antero_Hirvonen
More information about the Proj
