[Proj] Info on proj4 formulas
Mikhail Tchernychev misha at mail.geometrics.com
Fri May 9 11:28:40 PDT 2014
Well, it seems to me first part of your letter contradicts (1) and (2).
Anyway, if there is negligible difference (say in order of cm) than what
could come wrong friendly fire or drilling?
But I have to admit that consequences could be severe for surveyor in
two cases:
1. there is a legal requirement to use specific formulas.  In this case
we are in trouble
even the formulas yield exactly the same results but not recommended
ones were used.
2. If required formulas were distorted on purpose.   Then this is just a
case of classified information.
Best Regards,
Mikhail
On 5/9/2014 10:59 AM, Clifford J Mugnier wrote:
> Variations in projection formulae can be an academic exercise or a catastrophe, depending on the application.  Most GIS applications can use practically any truncation of the infinite series (4th order, 5th order, 6th order, etc.) with little to no effect to day-to-day work.  There are two exceptions:
> 1.)	Military.  Always use whatever is currently promulgated by NGA for NATO/SEATO applications.  This helps avoid “friendly fire” incidents among units that provide indirect fire support.
> 2.)	Oil and Gas.  Exploration and Production concessions leased by national governments use map projections for Grid Systems as legal coordinate systems sometimes based on specific truncations.  When that is in effect, the use of other truncations (especially in offshore areas) can produce catastrophic errors in positioning.
> Sometimes, mathematical distortions at various distances from the projection origin are on purpose!
> Cliff Mugnier
> LOUISIANA STATE UNIVERSITY
> ________________________________________
> From: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> on behalf of Hermann Peifer <peifer at gmx.eu>
> Sent: Friday, May 9, 2014 12:47 PM
> To: PROJ.4 and general Projections Discussions
> Subject: Re: [Proj] Info on proj4 formulas
> On 2014-05-09 16:31, Nick Ves wrote:
>> Intresting,
>> But now I'm wondering if the OGP's "Geomatics Guidance Note Number 7,
>> part 2 Coordinate Conversions and Transformations including Formulas"
>> [0] has been taken into account in the realizations of the formulas.
>> [0] http://www.ogp.org.uk/pubs/373-07-2.pdf
> At least Thomas Flemming mentions an earlier version of the guidance
> note, see http://trac.osgeo.org/proj/browser/trunk/proj/src/PJ_krovak.c
> Hermann
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
PLEASE NOTE: This message, including any attachments, may include privileged,
confidential and/or inside information. Any dissemination, distribution or copy
of this communication by   anyone other than the intended recipient is strictly
prohibited. If you are not the intended recipient, please notify the sender by
replying to this message and then delete it from your system. Information
provided via electronic media is not guaranteed against defects including
translation and transmission errors. The company accepts no liability for any
damage caused by any virus transmitted by this email.
Geometrics Inc. | 2190 Fortune Drive | San Jose, CA 95131 USA
