[Proj] ACT Standard Grid (AGD66)
Richard Greenwood
richard.greenwood at gmail.com
Mon Apr 13 17:18:23 PDT 2015
On Mon, Apr 13, 2015 at 11:39 AM, Hermann Peifer <peifer at gmx.eu> wrote:
> About +towgs84=-129.19,-41.21,130.73,-.25,-.37,-.33,-2.96
> The EPSG database has pretty similar values for coordinate operations
> 1458 and 1665, see e.g. at
> http://epsg-registry.org/export.htm?wkt=urn:ogc:def:coordinateOperation:EPSG::1665
> These values are however given according to METHOD: Coordinate Frame
> Rotation. You'd need to revert the sign of the rotation values, as
> explained in
> https://trac.osgeo.org/proj/wiki/GenParms#towgs84-DatumtransformationtoWGS84
> so you should use
> +towgs84=-129.19,-41.21,130.73,.25,.37,.33,-2.96
If you reverse the sign then shouldn't it be:
+towgs84=129.19,41.21,-130.73,-.25,-.37,-.33,2.96
or am I missing what you are suggesting?
Rich
I am however not so sure if this will help you to get rid of a 200m offset.
> Hermann
> On 2015-04-13 17:31, Michel.Dastous at bentley.com wrote:
> > Hi,
> > I’m currently trying to publish an Oracle dataset marked as SRID 82474
> > and cannot determine the proper proj4 init string corresponding to it.
> > I was able to extract the WKT definition from Oracle:
> > /PROJCS["ACT Standard Grid (AGD66)", GEOGCS [ "Australian Geodetic 1966
> > ACT", DATUM ["AGD 66 ACT", SPHEROID ["Australian", 6378160,
> > 298.25],-129.19,-41.21,130.73,-.25,-.37,-.33,-2.96], PRIMEM [
> > "Greenwich", 0.000000 ], UNIT ["Decimal Degree", 0.01745329251994330]],
> > PROJECTION ["Transverse Mercator"], PARAMETER ["Scale_Factor",
> > 1.000086], PARAMETER ["Central_Meridian", 149.0092948333], PARAMETER
> > ["False_Easting", 200000.000000], PARAMETER ["False_Northing",
> > 4510193.4939], UNIT ["Meter", 1.000000000000]]/
> > The best we have is:
> > /+proj=tmerc +lon_0=149.0092948333 +k=1.000086 +x_0=200000
> > +y_0=4510193.4939 +ellps=aust_SA
> > +towgs84=-129.19,-41.21,130.73,-.25,-.37,-.33,-2.96 +units=m +no_defs
> > Unfortunately this produce a displacement of around 200 meters when
> > reprojected to Bing coordinate system.
> > Can anyone help?
> > Thanks,
> > Michel
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150413/9a58e326/attachment.html>
More information about the Proj
