[Proj] PROJ.4 and OpenMP
Even Rouault
even.rouault at spatialys.com
Thu Jul 2 08:34:11 PDT 2015
Le jeudi 02 juillet 2015 16:25:50, José Luis García Pallero a écrit :
> Hello:
> Since version 4.8.0, PROJ.4 has some thread safety facilities
> (https://trac.osgeo.org/proj/wiki/ThreadSafety) and also the source
> code contains an example program in which Posix Threads are used. But
> I'm a bit confused about how to use this thread safety with OpenMP.
> Could someone, please, upload a code example of using PROJ with
> OpenMP? Such example could be also added to the distributed source
> code
José,
I don't have a working example to propose nor I am an OpenMP expert, but based
on https://en.wikipedia.org/wiki/OpenMP, I guess you must use a thread-private
identifier to select projPJ objects specific to each thread.
The global workflow could be :
- initialization :
projCtxt* tabProjCtx;
projPJ* tabProjSrc;
projPJ* tabProjDst;
int nThreads;
#pragma omp parallel
#pragma omp single
nThreads = omp_get_num_threads()
/* TODO: allocate tabProjCtx, tabProjSrc and tabProjDst to be nThreads
large */
/* TODO: loop over nThreads and initialize each tabProjCtx[i],
tabProjSrc[i] and tabProjDst[i] */
- and then use something like :
int th_id;
#pragma omp parallel for private(th_id)
for(i=0;i<...;i++)
th_id = omp_get_thread_num();
pj_transform(tabProjSrc[th_id], tabProjDst[th_id], ...)
Completely untested of course...
If you manage to get a working example, please contribute it.
Even
http://www.spatialys.com
More information about the Proj
