[Proj] AppVeyor (Windows CI) setup + Windows CMake question
Even Rouault even.rouault at spatialys.com
Sat Jul 4 12:13:25 PDT 2015
Similarly to Linux Travis-CI builds, I've also added the configuration for the
AppVeyor hosted CI service for Windows builds
:https://github.com/OSGeo/proj.4/blob/master/appveyor.yml
The following configurations are tested (for pushes and pull requests) :
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 10; Platform: x64
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 10; Platform: x86
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 11; Platform: x64
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 11; Platform: x86
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 12; Platform: x64
Environment: BUILD_TYPE=cmake, VS_VERSION=Visual Studio 12; Platform: x86
Environment: BUILD_TYPE=nmake; Platform: x64
Environment: BUILD_TYPE=nmake; Platform: x86
This only runs the build as I don't think there's a test target for Windows ?
Results available at:
https://ci.appveyor.com/project/OSGeo/proj-4
Travis and Appveyor badges displayed on:
https://github.com/OSGeo/proj.4/wiki
I've had a hard time with Windows cmake builds. I had to add  "-
DCMAKE_RUNTIME_OUTPUT_DIRECTORY_RELEASE=../bin" on the cmake line, otherwise I
got errors during the build with "..\bin\nad2bin.exe" not being found when
processing """
CustomBuild:
  Building Custom Rule c:/....../proj.4/nad/CMakeLists.txt
Is it expected?
Without that, the binaries are installed in bin\Release
Even
http://www.spatialys.com
