[Proj] Verifying cs2cs arguments
Even Rouault even.rouault at spatialys.com
Fri Jul 10 12:50:54 PDT 2015
Le vendredi 10 juillet 2015 05:48:03, Rob Parsons a écrit :
> Hello,
> Is there a way to verify the arguments that will be passed to cs2cs.exe
> before cs2cs.exe is used?
> cs2cs.exe is used from inside a python script. Is there a related tool that
> can verify the arguments that will be passed to cs2cs.exe?
Rob,
That doesn't directly answer your question (I believe the answer is no), but
https://pypi.python.org/pypi/pyproj/ might be a better option for using proj
from Python.
Even
http://www.spatialys.com
