[Proj] proj 4.9.1 released
Howard Butler
howard at hobu.co
Wed Mar 11 06:24:20 PDT 2015
> On Mar 11, 2015, at 7:12 AM, sisyphus1 at optusnet.com.au wrote:
> I notice that projects.h is being installed again by 'make install'. Was
> that intended ?
> If so, it's a welcome re-introduction.
> IIRC, recent builds of proj stopped installing projects.h because it was
> considered non-public API.
> No big deal ... just curious. I kept on (manually) installing projects.h,
> anyway.
It was put back for 4.9.0, but we didn't actually have that release :)
http://trac.osgeo.org/proj/ticket/220
> I've just built 4.9.1 on native MS Windows using a variety of mingw ports of
> 32-bit and 64-bit gcc compilers - using autotools in the msys shell.
> (I hope that autotools support is here to stay for a while yet - that there
> are no plans to soon *replace* it with cmake.)
There is no intention to replace autotools with CMake. The CMake stuff is in addition to the autoconf build support, which has been there for eons, and it will continue to stay as painful as possible, as always. I will say there is some intention to replace the hand-rolled MSVC nmake scripts with CMake :), but the audience for that is predictably quite small.
Howard
More information about the Proj
