[Proj] why doesn't the epsg file reference the hpgn grids?
Richard Greenwood richard.greenwood at gmail.com
Wed Mar 18 06:14:53 PDT 2015
On Tue, Mar 17, 2015 at 9:53 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> As most of the "heavy" grids are not directly distributed with proj, it
> might be
> tricky to propose a reasonable +nadgrids parameter. Although we could use
> the @
> syntax to make their presence optional.
What is the "@ syntax"?
> But there's currently no way of doing
> the association between a datum and corresponding grids when the "raw" CSV
> files
> are processed in the gcs.csv/pcs.csv. Perhaps something similar to
> http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/datum_shift_pref.csv
> could be used.
I'm still unclear as to how epsg.org addresses grid shifts. I randomly
surfed thru the files in
<http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/datum_shift_pref.csv>
and
found no clues. It seems like it would be nice to enhance the processing of
the epsg.org source definitions to reference grid shift files if possible.
By "if possible" I mean if there is sufficient information in the epsg.org
source definitions to do that. If not, then I agree that something
like datum_shift_pref.csv would be good.
Thanks,
Rich
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150318/f252e175/attachment.html>
