[Proj] Use the GTX null value for vertical shift exclusion.
paul.chavent at fnac.net paul.chavent at fnac.net
Fri Mar 27 08:04:44 PDT 2015
Hi.
Vertical grid shift values specified with GTX files are  rejected outside of the [-1000;1000] range. I don't know if it is the  expected behavior since the GTX files allow any values excepted the null  value.
I've opened a ticket (http://trac.osgeo.org/proj/ticket/271) to address this issue. I've submitted a patch that use the 88.88880 null value for rejecting bad values.
Perhaps a better fix would be to add a null_value (or range) field to the CTABLE and check against this value (or range).
Regards.
Paul.
