[Proj] EPSG-Code Definition for MGI
Dirk Peinelt
dirk.peinelt at t-online.de
Mon Nov 2 06:35:11 PST 2015
Yes, the same as spatialreference.org with 7-point-setting. (towgs84)
But in proj.4 there is a another definition string in ./nad/epsg
//dirk
----- Ursprüngliche Nachricht -----
Von: "Markus Neteler" <neteler at osgeo.org>
Gesendet: 02.11.2015 15:02
An: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Betreff: Re: [Proj] EPSG-Code Definition for MGI
On Mon, Nov 2, 2015 at 1:09 PM, Dirk Peinelt <dirk.peinelt at t-online.de> wrote:
> Hello,
> the EPSG-code definitions for 31256 - 31258 (MGI = Austrian date) on the
> master are different with spatialreference.org.:
> https://github.com/OSGeo/proj.4/blob/master/nad/epsg/
> http://spatialreference.org/ref/epsg/31256/proj4/
> http://spatialreference.org/ref/epsg/31257/proj4/
> http://spatialreference.org/ref/epsg/31258/proj4/
> Could be here a bug in proj.4 EPSG database?
To my knowledge http://spatialreference.org is rather dated (on the
respective OSGeo server I see only file timestamps older than several
years).
Alternative:
http://epsg.io/31256
etc. Does this fit better?
best.
Markus
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20151102/ff7c0bed/attachment.html>
More information about the Proj
