[Proj] Switch utm from tmerc to etmerc
Even Rouault
even.rouault at spatialys.com
Mon Oct 26 01:48:29 PDT 2015
Le lundi 26 octobre 2015 00:09:10, Roger Bivand a écrit :
> Charles Karney <charles.karney <at> sri.com> writes:
> > This change has now been made to the master branch of the source. The
> > "utm projection" now follows the NGA recommendation and uses etmerc
> > instead of tmerc (which is less accurate). You can expect small
> > (typically < 1mm, except at high latitudes) changes in the results for
> > the utm projection.
> While correcting wrong parameterisations is good, here we are doing what
> the mooted metacrs definitions were trying to avoid, that is altering
> in-place code without user-facing versioning. Different versions (by
> commit hashes now) of the underlying code will now give different answers,
> so re-running an analysis with the same data and apparently the same code
> in software linking to proj will give different answers, without the user
> necessarily being able to re-instate the earlier relationship. It would be
> great to bear in mind the fact that research does need to be reproducible
> (data from times before this correction was known don't need to be obliged
> to use it). I guess we have to assume that users really read commit logs
> and NEWS files.
Roger,
I'm not in the business of reproducible research but I guess that if you want
things to be perfectly reproducible you'd have to specify all the environment:
exact software versions, probably with their compilation options and versions
of their dependencies, OS version, and possibly hardware that was used.
Even
> Roger
> > --Charles
> > On 10/06/2015 11:19 AM, Charles Karney wrote:
> > > Reposted from
> > > https://github.com/OSGeo/proj.4/issues/316
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the Proj
