[Proj] Missing proj_def.dat in 4.9.1 release
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Sep 6 11:13:14 PDT 2015
On 06-09-15 17:55, Roger Bivand wrote:
> Please may I ask when a new release will be forthcoming to remedy the
> serious shortcoming of the 4.9.1 release? This has now propogated and is
> causing chaos in uses in the R world. For example, the Debian proj-data
> package does not have proj_def.dat, I don't know about other distributions.
As a temporary solution for this problem, I've updated the proj Debian
package to install proj_def.dat again.
The just uploaded proj (4.9.1-3) contains two patches, the first adds
nad/proj_def.dat as currently on the GitHub master branch, the second is
the nad/Makefile.am change by hobu to install proj_def.dat again.
proj (4.9.1-3) should migrate to testing in 5 days. Ubuntu should pick
it up soon for the upcoming wily release.
I'm not sure what the procedure is to generate release tarballs, so I
couldn't test if the Makefile.am change is sufficient to have
proj_def.dat included in the release tarballs too.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
