[Proj] Missing proj_def.dat in 4.9.1 release
Thomas Knudsen
knudsen.thomas at gmail.com
Mon Sep 7 06:17:10 PDT 2015
I definitely agree with Greg: Autogenerated files have nothing to do under
source control. They are not source files, after all.
/thomas
2015-09-07 15:01 GMT+02:00 Greg Troxel <gdt at ir.bbn.com>:
> Even Rouault <even.rouault at spatialys.com> writes:
> > And I've added also additional fixes : proj_def.dat was also missing in
> cmake,
> > and there were also other 4 files in nad/ that weren't in the
> EXTRA_DIST. I
> > realized that when adding a "self-consistency" check in .travis.yml:
> basically
> > I do a make install from the git checkout, then a make dist-all, build
> and
> > install (in another target dir) from the archive generated by make
> dist-all,
> > and compare the list of installed files (
> https://github.com/OSGeo/proj.4/commit/ba3454ec0f9d1d33e165d0ace70f766c8283892e
> "make distcheck" is helpful. It produces a distfile, and then unpacks
> it and does a build with a different objdir and then runs make check in
> that.
> > Another related topic is : what should be the policy with
> automake/autoconf
> > generated files in git :
> > - regenerate them and commit them each time they are modified.
> Advantage: the
> > export from git is always valid. Drawback: it is easy to forget
> regenerating
> > - regenerate them only just before release time (so travis build would
> need to
> > run ./autogen.sh)
> > - drop them from git completely ( that's what is suggested by
> > https://github.com/OSGeo/proj.4/pull/282 )
> my $0.02:
> * Definitely remove them, and tell people run autogen.sh to create them
> when building from git. This is the normal practice and works well.
> * Define that the only valid way to create a release tarball is "make
> dist". (I'm not sure what else you mean by "export from git".)
> (I maintain the proj package in pkgsrc, a multi-arch multi-OS packaging
> system.)
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150907/757221e1/attachment.html>
More information about the Proj
