[Proj] Missing proj_def.dat in 4.9.1 release
Greg Troxel
gdt at ir.bbn.com
Mon Sep 7 10:34:28 PDT 2015
Howard Butler <howard at hobu.co> writes:
> My preference is also to remove them entirely, but we need to have
> some kind of policy on what the autotools/automake variant is that
> does 'make dist' that ultimately makes the distribution for
> release. If I were to do 'make dist' from my OSX environment and then
> release that, many would not be happy with it, for example. We have
> this same challenge in libgeotiff too.
Sure, that's reasonable. Probably autoconf/automake need to have the
minimum versions declared in their source files, and arguably that
should be good enough.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150907/dd6b8f26/attachment.sig>
More information about the Proj
