[Proj] Missing proj_def.dat in 4.9.1 release
Elliott Sales de Andrade
quantum.analyst at gmail.com
Mon Sep 7 22:32:34 PDT 2015
Hi Even,
On 7 September 2015 at 05:40, Even Rouault <even.rouault at spatialys.com>
wrote:
> Another related topic is : what should be the policy with automake/autoconf
> generated files in git :
> - regenerate them and commit them each time they are modified. Advantage:
> the
> export from git is always valid. Drawback: it is easy to forget
> regenerating
> - regenerate them only just before release time (so travis build would
> need to
> run ./autogen.sh)
> - drop them from git completely ( that's what is suggested by
> https://github.com/OSGeo/proj.4/pull/282 )
Thanks for bringing this up on the list. Ever since your post, I've been
meaning to do so but became too busy to do so. Since the consensus so far
appears in favour, I'll make sure to rebase so that there are no longer any
merge conflicts.
Elliott
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150908/47fa99ee/attachment.html>
More information about the Proj
