[Proj] Question on +czech option
Clifford J Mugnier
cjmce at lsu.edu
Thu Aug 11 11:01:02 PDT 2016
I can send a copy of:
Krovak Projection and its Using for Czechia
Prof. Ing. Bohuslav Veverka, DrSc.
Czech Technical University
Dated 2003
To anyone that wants one. It is a Word document.
Clifford J. Mugnier, CP,CMS,FASPRS
Chief of Geodesy,
Center for GeoInformatics (C4G)
266 ERAD (Research)
3335 PFT (Academic)
Dept. of Civil & Environmental Engineering
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA 70803
Research 225-578-4578
Academic 225-578-8536
Cell 225-328-8975
On 8/11/16, 12:47 PM, "proj-bounces at lists.maptools.org on behalf of vanadovv at hetnet.nl" <proj-bounces at lists.maptools.org on behalf of vanadovv at hetnet.nl> wrote:
>The Original Krovak projection from 1922 has south-west axes, some years ago they changed to north-east.
>So says the EPSG Guidance Note 7-1 (IOGP Publication 373-7-2 – Geomatics Guidance Note number 7, part 2) in the Krovak chapter.
>Oscar van Vlijmen
>>----Origineel Bericht----
>>Van : mkennedy2 at earthlink.net
>>Datum : 11/08/2016 01:48
>>Aan : proj at lists.maptools.org
>>Onderwerp : [Proj] Question on +czech option
>>I am wondering if the parameter/option +czech is working correctly.
>>If anyone is unfamiliar with it, this option is used with +proj=krovak, the Krovak projection used in former Czechoslovakia (and current Czech Republic).
>>The 'native' Krovak has positive south, west axes (given in that order according to EPSG). Many Czech users are happy to use east, north axes in order to use various software packages that don't support multiple axis directions.
>>Using an input point of latitude = 50, longitude = 20, I got these results (point is a little nonsensical due to using Ferro prime meridian in the tests):
>>with czech (2065)
>>cs2cs +to +proj=krovak +ellps=bessel +pm=ferro +x_0=0.0 +y_0=0.0
>> +lon_0=42d30'E +lat_0=49d30'N +k_0=0.9999 +czech +no_defs
>> cs2cs - PJ lib: 1589829.67 864777.51
>> forward 2065 : 864777.51 1589829.67 (Esri projection engine)
>>without czech (5211)
>> +lon_0=42d30'E +lat_0=49d30'N +k_0=0.9999 +no_defs
>> cs2cs - PJ lib: -1589829.67 -864777.51
>> forward 5211 : -1589829.67 -864777.51 (Esri projection engine)
>>So without the +czech option, we get east, north axes. With +czech, we get values in west, south axes order, rather than south, west. Is this correct behavior?
>>Disclosure: I work at Esri and I'm on the subcommittee that maintains the EPSG Geodetic Registry.
>>Melita
>>Melita Kennedy
>>Esri Sr. Product Engineer
>>_______________________________________________
>>Proj mailing list
>>Proj at lists.maptools.org
>>http://lists.maptools.org/mailman/listinfo/proj
>Proj mailing list
Type: application/octet-stream
Desc: default.vnd.ms-officetheme
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160811/f90a9bc5/attachment.obj>
More information about the Proj
