[Proj] Geodetic datum for the "Netherlands East Indies Southern Zone"?
Mikael Rittri Mikael.Rittri at carmenta.com
Thu Mar 3 23:18:18 PST 2016
Hello all,
I have come across an Indonesian map. In the legend, it says
that the ellipsoid is Bessel and the projection is Lambert Conic
Orthomorphic. The projection parameters agree with the "Netherlands
East Indies Southern Zone", covering Java and the Lesser Sunda Islands,
as described by Clifford Mugnier in his column on Indonesia (page 1160,
left column).
http://www.asprs.org/a/resources/grids/10-2009-indonesia.pdf
The projection is not listed in the EPSG database, as far as I can see.
What I am not sure of, is the geodetic datum. The graticule of the
map showed longitudes from Jakarta, but that doesn't help much, since
many local geodetic datums in Indonesia use Jakarta as the prime meridian.
In the EPSG database, the only geodetic datums that fit - using the
Bessel ellipsoid and covering Java - are Batavia and Batavia (Jakarta),
EPSG codes 6211 and 6813. And I noticed that the "Netherlands East
Indies Equatorial Zone", also mentioned by Mugnier, is listed in
EPSG (code 3001), and uses the Batavia datum.
Can I conclude that the Netherlands East Indies Southern Zone also
uses the Batavia datum, or could it use some other datum that is
not listed by EPSG?
Regards,
MikaelĀ Rittri
Carmenta
Sweden
http://www.carmenta.com
