[Proj] Proj4 and Epoch
Greg Troxel
gdt at ir.bbn.com
Mon Mar 7 17:58:49 PST 2016
barronian <ian at roqc.no> writes:
> Is there support for Epoch in Proj4 ?
> If so could you please give me a pointer as to how to access the
> functionality?
That's a really good question. I've been on this list for a long time
and haven't seen any.
proj4 uses EPSG codes. I think a question to answer first is how EPSG
codes represent epoch.
For example (US centric :-), NAD 83 has many incarnations, but arguably
the standard one is "NAD83(2011)":
http://epsg.io/6318
However this doesn't talk about epoch at all. Arguably coordinates in
EPSG 6318 are epoch 2010.0, following:
http://geodesy.noaa.gov/CORS/coords.shtml
But, it's not clear to me how to represent a different epoch, or to talk
about velocities in EPSG or proj4 at all.
So, I suspect you have to transform to the standard epoch in some frame,
and then to another frame, and then to the epoch you want.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160307/d05f0152/attachment.sig>
More information about the Proj
