[Proj] Proj4 and Epoch
    support at mnspoint.com
    Tue Mar 15 09:41:56 PDT 2016
barronian kirjoitti 08.03.2016 02:18:
> Is there support for Epoch in Proj4 ?
No, time is not at all handled anyway by the library .. Proj4 is only a
very simple library to do the most common projection transformations and
usual datum shifts. If you have time dependent matters you have to firts
transform the time to a datum shift and then feed it into the library.
Regards: Janne.
More information about the Proj
