[Proj] Original Latex Files?
Agnew, Duncan
dagnew at ucsd.edu
Tue Mar 15 10:28:15 PDT 2016
Two notes:
The first, and probably the second, document are publications of the US government and thus in the public
domain.
It isn't difficult to extract the text from the .pdf file, but putting all the LaTeX formatting back would be a lot
of work -- though it would not be difficult to "parallelize" this, with a little community organization.
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of support at mnspoint.com [support at mnspoint.com]
Sent: Tuesday, March 15, 2016 10:11 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Original Latex Files?
Hello,
I haven't heard anything about Gerald since many years and also Frank
been very silent lately. I suppose Frank might have an idea if anybody
here? I think Gerald is (if anywhere) more active on the "libproj" side?
.. if Proj4 was written sometime 1970 first time .. you can count years
your self etc..
If nothing else helps it might be a good time to write them again using
the originals as basis?! (And also compile them all together into a
single manual) .. ??!! Most likely no copyright problems exsist if
original writers are mentioned etc. etc..
It is also possible that any original manual files are lost for ever?!
.. lucky we have the source code still! :)
Regards: Janne.
Howard Butler kirjoitti 14.03.2016 20:52:
> Gerald (or maybe others)?
> As part of the website and documentation remodel for proj.4, it would
> be really nice if we could collect the content of the various PDFs
> into a living document.
> ftp://ftp.remotesensing.org/proj/OF90-284.pdf
> ftp://ftp.remotesensing.org/proj/proj.4.3.pdf
> ftp://ftp.remotesensing.org/proj/proj.4.3.I2.pdf
> Would it be possible to get the source latex files for these
> documents, and would you support us including them as part of a larger
> documentation effort for http://proj4.org?
> Thanks much,
> Howard
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
