[Proj] Original Latex Files?
Kristian Evers
kreve at sdfe.dk
Wed Mar 16 03:53:33 PDT 2016
Postscript files for the PROJ.4.3.*.pdf files can be found here:
http://download.osgeo.org/proj/from_kai/
I've been trying to find the code that was used to create the plots in the files, but haven't had any luck yet. It should be possible to extract the plots from the ps-file though.
Kristian Evers
Geophysicist
Geographical references
kreve at sdfe.dk
Danish Ministry of Energy, Utilities and Climate
Agency for Data Supply and Efficiency
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af Norman Vine
Sendt: 16. marts 2016 10:57
Til: PROJ.4 and general Projections Discussions
Emne: Re: [Proj] Original Latex Files?
this seems to be a mirror copy of Gerald's last USGS distribution site charon.er.usgs.gov
http://ftp.funet.fi/pub/graphics/packages/MapProjections/
there are a couple of postscript files there that might be useful
PROJ.4.?.ps.Z Intermim documentation of release 4 proj. Use as
a supplement to OF 90-284 (listed above). PostScript for
300dpi, black-on-white printers.
proj.OF90-284.ps directory of PostScript files to create proj's OF doc-
umentation on a 300bpi, black-on-white laser printer.
On Mar 15, 2016, at 1:28 PM, "Agnew, Duncan" <dagnew at ucsd.edu> wrote:
> Two notes:
> The first, and probably the second, document are publications of the US government and thus in the public
> domain.
> It isn't difficult to extract the text from the .pdf file, but putting all the LaTeX formatting back would be a lot
> of work -- though it would not be difficult to "parallelize" this, with a little community organization.
> ________________________________________
> From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of support at mnspoint.com [support at mnspoint.com]
> Sent: Tuesday, March 15, 2016 10:11 AM
> To: PROJ.4 and general Projections Discussions
> Subject: Re: [Proj] Original Latex Files?
> Hello,
> I haven't heard anything about Gerald since many years and also Frank
> been very silent lately. I suppose Frank might have an idea if anybody
> here? I think Gerald is (if anywhere) more active on the "libproj" side?
> .. if Proj4 was written sometime 1970 first time .. you can count years
> your self etc..
> If nothing else helps it might be a good time to write them again using
> the originals as basis?! (And also compile them all together into a
> single manual) .. ??!! Most likely no copyright problems exsist if
> original writers are mentioned etc. etc..
> It is also possible that any original manual files are lost for ever?!
> .. lucky we have the source code still! :)
> Regards: Janne.
> Howard Butler kirjoitti 14.03.2016 20:52:
>> Gerald (or maybe others)?
>> As part of the website and documentation remodel for proj.4, it would
>> be really nice if we could collect the content of the various PDFs
>> into a living document.
>> ftp://ftp.remotesensing.org/proj/OF90-284.pdf
>> ftp://ftp.remotesensing.org/proj/proj.4.3.pdf
>> ftp://ftp.remotesensing.org/proj/proj.4.3.I2.pdf
>> Would it be possible to get the source latex files for these
>> documents, and would you support us including them as part of a larger
>> documentation effort for http://proj4.org?
>> Thanks much,
>> Howard
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Proj mailing list
More information about the Proj
