[Proj] Using invproj to get back the inputs to proj
Dean Schulze dschulze at wirelessseismic.com
Mon May 16 10:24:37 PDT 2016
Following the example in the man page if I do
    proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt
where the file man.page.lat.lon.txt contains
    45d15'33.1"   111.5W
    45d15.551666667N   -111d30
    +45.25919444444    111d30'000w
I get the 3 lines of output shown in the man page:
   460769.27	5011648.45
So far, so good.  But when I try to use invproj to get back the original inputs the results are not even close to the inputs:
    proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +lon_0=112w +ellps=clrk66 -r
gives
    73d25'28.89"W	3d18'2.678"N
What is invproj giving me?  How do I run invproj to get back my original inputs?
Apparently invproj doesn't use command line parameters the same way that proj does.  Is this documented somewhere?  I've read the 3 .pdfs provides as users manuals, but they say nothing about how to use invproj to get back the original inputs.
Thanks.
