[Proj] Using invproj to get back the inputs to proj
Dean Schulze
dschulze at wirelessseismic.com
Tue May 17 07:54:06 PDT 2016
Leaving off the -r on invproj gives me back the correct latitude, but the longitude is even worse:
$ proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +ellps=clrk66
# proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt
# Should give
# 460769.27 5011648.45
3d30'W 45d15'33.1"N
3d30'W 45d15'33.1"N
3d30'W 45d15'33.1"N
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of Thomas Knudsen [knudsen.thomas at gmail.com]
Sent: Monday, May 16, 2016 11:59 PM
To: PROJ. 4 and general Projections Discussions
Subject: Re: [Proj] Using invproj to get back the inputs to proj
Try to leave out the -r option in invproj: the output of proj, that you feed into invproj is not in reverse order.
Also, do not expect identical output, especially not for data points far off the central meridian.
/Thomas
Den 16. maj 2016 19.26 skrev "Dean Schulze" <dschulze at wirelessseismic.com<mailto:dschulze at wirelessseismic.com>>:
Following the example in the man page if I do
where the file man.page.lat.lon.txt contains
45d15'33.1" 111.5W
45d15.551666667N -111d30
+45.25919444444 111d30'000w
I get the 3 lines of output shown in the man page:
So far, so good. But when I try to use invproj to get back the original inputs the results are not even close to the inputs:
proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +lon_0=112w +ellps=clrk66 -r
gives
73d25'28.89"W 3d18'2.678"N
What is invproj giving me? How do I run invproj to get back my original inputs?
Apparently invproj doesn't use command line parameters the same way that proj does. Is this documented somewhere? I've read the 3 .pdfs provides as users manuals, but they say nothing about how to use invproj to get back the original inputs.
Thanks.
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
