[Proj] Using invproj to get back the inputs to proj
Dean Schulze
dschulze at wirelessseismic.com
Tue May 17 15:15:29 PDT 2016
Thanks Andre. Leaving off the lon_0 was the problem.
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of Andre Joost [andre+joost at nurfuerspam.de]
Sent: Tuesday, May 17, 2016 12:09 PM
To: proj at lists.maptools.org
Subject: Re: [Proj] Using invproj to get back the inputs to proj
Am 17.05.2016 um 16:54 schrieb Dean Schulze:
> Leaving off the -r on invproj gives me back the correct latitude, but the longitude is even worse:
> $ proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +ellps=clrk66
> # proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt
> # Should give
> # 460769.27 5011648.45
> 3d30'W 45d15'33.1"N
> 3d30'W 45d15'33.1"N
> 3d30'W 45d15'33.1"N
> From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of Thomas Knudsen [knudsen.thomas at gmail.com]
> Sent: Monday, May 16, 2016 11:59 PM
> To: PROJ. 4 and general Projections Discussions
> Try to leave out the -r option in invproj: the output of proj, that you feed into invproj is not in reverse order.
> Also, do not expect identical output, especially not for data points far off the central meridian.
> /Thomas
> Den 16. maj 2016 19.26 skrev "Dean Schulze" <dschulze at wirelessseismic.com<mailto:dschulze at wirelessseismic.com>>:
> Following the example in the man page if I do
> where the file man.page.lat.lon.txt contains
> 45d15'33.1" 111.5W
> 45d15.551666667N -111d30
> +45.25919444444 111d30'000w
> I get the 3 lines of output shown in the man page:
> So far, so good. But when I try to use invproj to get back the original inputs the results are not even close to the inputs:
> proj +proj=utm +lon_0=112w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +lon_0=112w +ellps=clrk66 -r
> gives
> 73d25'28.89"W 3d18'2.678"N
> What is invproj giving me? How do I run invproj to get back my original inputs?
You have missed the lon_0 in invproj, so it takes it to Greenwich.
HTH,
André Joost
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
