[Proj] Using invproj to get back the inputs to proj
Davide Cesari dcesari at arpa.emr.it
Wed May 18 00:03:05 PDT 2016
Hello Dean, it seems you forgot "+lon_0=112w" in the invproj string, I
get the correct result with the following command:
echo "45.25919444444 -111.5" | \
  proj +proj=utm +lon_0=112w +ellps=clrk66 -r | \
  invproj +proj=utm +lon_0=112w  +ellps=clrk66
111d30'W	45d15'33.1"N
	Davide
On 17/05/2016 16:54, Dean Schulze wrote:
> Leaving off the -r on invproj gives me back the correct latitude, but the longitude is even worse:
> $ proj +proj=m +lon_02w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm  +ellps=clrk66
> #	proj +proj=m +lon_02w +ellps=clrk66 -r man.page.lat.lon.txt
> #	Should give
> #		460769.27     5011648.45
> 3d30'W	45d15'33.1"N
> 3d30'W	45d15'33.1"N
> 3d30'W	45d15'33.1"N
> ________________________________________
> From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] on behalf of Thomas Knudsen [knudsen.thomas at gmail.com]
> Sent: Monday, May 16, 2016 11:59 PM
> To: PROJ. 4 and general Projections Discussions
> Subject: Re: [Proj] Using invproj to get back the inputs to proj
> Try to leave out the -r option in invproj: the output of proj, that you feed into invproj is not in reverse order.
> Also, do not expect identical output, especially not for data points far off the central meridian.
> /Thomas
> Den 16. maj 2016 19.26 skrev "Dean Schulze" <dschulze at wirelessseismic.com<mailto:dschulze at wirelessseismic.com>>:
> Following the example in the man page if I do
> where the file man.page.lat.lon.txt contains
>      45d15'33.1"   111.5W
>      45d15.551666667N   -111d30
>      +45.25919444444    111d30'000w
> I get the 3 lines of output shown in the man page:
> So far, so good.  But when I try to use invproj to get back the original inputs the results are not even close to the inputs:
>      proj +proj=m +lon_02w +ellps=clrk66 -r man.page.lat.lon.txt | invproj +proj=utm +lon_02w +ellps=clrk66 -r
> gives
>      73d25'28.89"W       3d18'2.678"N
> What is invproj giving me?  How do I run invproj to get back my original inputs?
> Apparently invproj doesn't use command line parameters the same way that proj does.  Is this documented somewhere?  I've read the 3 .pdfs provides as users manuals, but they say nothing about how to use invproj to get back the original inputs.
> Thanks.
> Proj mailing list
> Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
> http://lists.maptools.org/mailman/listinfo/proj
============================= Davide Cesari ============================
Dott**(0.5) Davide Cesari
Arpæ Emilia Romagna, Servizio IdroMeteoClima
NWP modelling - Modellistica numerica previsionale
Tel. +39 051525926
