[Proj] Performance impact of switch of utm to etmerc
Even Rouault even.rouault at spatialys.com
Mon May 23 15:49:43 PDT 2016
I've given a try with proj master with GDAL, and wanted to assess the
performance impact of utm now using etmerc instead of tmerc.
Given a in.tif raster of 5000x5000 pixels in EPSG:3857, I did :
$ time gdalwarp in.tif out.tif  -t_srs EPSG:32611 -overwrite -et 0 -q
This runs in 18.1 s. With proj 4.9.2, the same runs in 13.6 s
EPSG:32611 is resolved by GDAL as "+proj=utm +zone=11 +ellps=WGS84 +units=m
+no_defs"
I added explicitly -et 0 so that the exact transformer of GDAL is used,
meaning that 5042x5019 inverse projections will be done (number of pixels of
output dataset). By default GDAL would use an approximate linear interpolation
transformer leading to very few transformations, and the time spent in proj is
then almost neglectable. But with -et 0, reprojection work becomes really
significant. It should be noted that -et 0 is the default if doing RPC
transformation with a DEM since GDAL 2.1.0 (since DEM have no nice regularity,
an approximate interpolator can do really bad guesses in mountain areas), and
this will probably the use case mostly affected by this.
To come back to previous performance, I've added in GDAL the possibility to
define the OSR_USE_ETMERC=NO configuration option/environment variable so that
"+proj=utm" is expanded to the appropriate "+proj=tmerc ...."
Best regards,
Even
http://www.spatialys.com
