[Proj] convert from Equidistant Cylindrical to Eckert I
Jose Gonçalves
jagoncal at gmail.com
Tue May 24 16:03:02 PDT 2016
Hi
You can transform your image with the following command line:
gdalwarp -s_srs "+ellps=WGS84 +proj=eqd" -t_srs "+ellps=WGS84 +proj=eck1"
in.tif out.tif
The input image must be georeferenced in the equidistant cylindrical
projection, with units in meters. See page http://www.gdal.org/gdalwarp.html.
Other important options are -r, -te and -tr.
Regards
José Gonçalves
2016-05-24 23:16 GMT+01:00 Wang Leslie <wqyuwss at hotmail.com>:
> Hi Norman, Dann,
> Thanks for quick reply. It would be highly appreciated for one sample
> command on these tools to achieve my goal.
> Best Regards
> Leslie
> ________________________________________
> From: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org>
> on behalf of Norman Vine <nhv at cape.com>
> Sent: Tuesday, May 24, 2016 7:20 AM
> To: PROJ.4 and general Projections Discussions
> Subject: Re: [Proj] convert from Equidistant Cylindrical to Eckert I
> Hello Leslie
> I suggest using http://www.gdal.org/gdalwarp.html todo this
> To avoid the speckling that Daan mentions you want to loop over the new
> image
> pixels and do the inverse projection to find the pixel value in the
> original image
> gdalwarp takes care of this for you and is built on top of the proj library
> Norman
> > On May 24, 2016, at 3:05 AM, strebe at aol.com wrote:
> > Hello Leslie.
> > Your procedure will work. The results will be heavily aliased, which
> will look like speckling. Some values of (x₁, y₁) will be empty unless the
> destination map is considerably smaller than the source image.
> > Regards,
> > — daan Strebe
> > -----Original Message-----
> > From: Wang Leslie <wqyuwss at hotmail.com>
> > To: proj <proj at lists.maptools.org>
> > Sent: Mon, May 23, 2016 7:37 am
> > Subject: [Proj] convert from Equidistant Cylindrical to Eckert I
> > Dear all,
> > I'm new to this tool, and hope to get some advise here.
> > I'm thinking to use your tool to convert a map picture which is based on
> Equidistant Cylindrical, to another picture based on Eckert I. Since both
> of them are 2 dimension only (x,y), what I'm gonna to do is:
> > - Use proj command to calculate the new mapped coordinate (x1, y1)
> > - Set new pixel value at (x1, y1) using original pixel value (x,y)
> > - loop for all pixel at original Equidistant Cylindrical picture
> > So can you please help me confirm if one idea can work or not? If yes,
> what should command line look like? Thanks.
> > Best Regards
> > Leslie Qi Wang
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> > Proj mailing list
> Proj mailing list
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160525/2a973b28/attachment.html>
More information about the Proj
