[Proj] Amersfoort / RD New
    Roger Oberholtzer
    roger.oberholtzer at gmail.com
    Tue Nov  1 04:33:15 PDT 2016
I am trying to get the Amersfoort / RD New projection working with
proj4. The users (a road authority in the Netherlands) claim to use
this definition with ESRI:
PROJCS["RD_New",GEOGCS["GCS_Amersfoort",DATUM["D_Amersfoort",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Double_Stereographic"],
PARAMETER["False_Easting",155000.0],
PARAMETER["False_Northing",463000.0],
PARAMETER["Central_Meridian",5.38763888888889],
PARAMETER["Scale_Factor",0.9999079],
PARAMETER["Latitude_Of_Origin",52.15616055555555],UNIT["Meter",1.0]]
I have started with the definition at
http://spatialreference.org/ref/epsg/amersfoort-rd-new/proj4/. The
projections from that are 100 meters from where they should be. I have
seen claims that the Spatial Reference definition is incorrect, and
that a better one is (it adds the +towgs84):
“+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
+towgs84=565.4174,50.3319,465.5542,-0.398957388243134,0.343987817378283,-1.87740163998045,4.0725
+units=m +no_defs”
Still no joy. My source values are WGS84 lat/long from a GPS receiver.
Anyone have the correct proj4 definition for this?
Roger Oberholtzer
More information about the Proj
