[Proj] Grid shift files.
Roger Oberholtzer
roger.oberholtzer at gmail.com
Wed Nov 2 03:31:43 PDT 2016
On Wed, Nov 2, 2016 at 9:41 AM, Bas Couwenberg <sebastic at xs4all.nl> wrote:
> On 2016-11-02 09:11, Roger Oberholtzer wrote:
> > On Tue, Nov 1, 2016 at 4:06 PM, Bas Couwenberg <sebastic at xs4all.nl>
> > wrote:
> >> Which has been fixed in 4.9.3 with:
> >> https://github.com/OSGeo/proj.4/pull/349
> > I have updated to 4.9.3 as a test. However, I am still not seeing the
> > grid
> > file even being accessed. It has to at least try to open it, right? I
> > don't
> > even see it try and fail. It simply does not try.
> Yes, if you enable PROJ.4 debug output (using the PROJ_DEBUG=3
> environment variable) your should see pj_open_lib(rdtrans2008.gsb) and
> pj_open_lib(naptrans2008.gtx).
> From the debug output I linked in the earlier message out this issue:
> Test: 05 Zuid-Limburg
> Exec: cs2cs -r +init=epsg:4258 +to +init=rdnap:rdnap -f %.4f
> Input: 50.792584908 5.773795547 174.9478
> STDERR: pj_open_lib(epsg): call fopen(./epsg) - succeeded
> pj_open_lib(rdnap): call fopen(./rdnap) - succeeded
> pj_open_lib(rdtrans2008.gsb): call fopen(./rdtrans2008.gsb) - succeeded
> NTv2 NL_ALL 63x65: LL=(2.5,50.5) UR=(7.66666667,55.8333333)
> NTv2 NL_LAND 561x421: LL=(3,50.5) UR=(7.66666667,54)
> NTv2 - loading grid NL_LAND
> pj_apply_gridshift(): used NL_LAND
> pj_open_lib(naptrans2008.gtx): call fopen(./naptrans2008.gtx) -
> succeeded
> GTX 311x641: LL=(2.5,50.5) UR=(7.66666667,55.8333333)
> succeeded
> pj_apply_gridshift(): used GTX Vertical Grid Shift File
> Output: 182260.4500 311480.6701 129.0000
> Expect: 182260.4500 311480.6700 129.000
> Test OK: From ETRS89 to RD/NAP - 05 Zuid-Limburg (Not identical, but
> within margin)
I get:
% PROJ_DEBUG=3 cs2cs -r +to +init=rdnap:rdnap -f %.4f
pj_open_lib(rdnap): call fopen(/opt/rsoft/lib/proj/rdnap) - succeeded
pj_open_lib(proj_def.dat): call fopen(/opt/rsoft/lib/proj/proj_def.dat) -
succeeded
fopen(/opt/rsoft/lib/proj/naptrans2008.gtx) - succeeded
182225.9086 311388.1617 128.9976
I wonder why I don't get the NTv2 debug statements.
Roger Oberholtzer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161102/7f616cb2/attachment.html>
More information about the Proj
