[Proj] A re-rationalized API for PROJ.4
support at mnspoint.com support at mnspoint.com
Mon Nov 14 01:42:23 PST 2016
ok,
... but NO thanks! .. if it does not add anything new .. for example a
new projection .. we do NOT want to have it!! --- it is just some
rewriting which forces all users to do some tricks and hours of extra
work etc. with their working code without actually adding anything
usable.
Please, do not make such changes that are not required!! -- fix bugs and
add some **useful** features ... but do not play with the coding ...
since that already works! (We actually PREFER to have it old fashion
than anything new and stupid!) --- if you like to make a "clean" Proj.4
for yourself just rename it something else and use it! --- but do not
mess with the current version ... we have had enough about those idiots
that believe they have some KING ideas how everybody should write
programs. And then after next 10 years comes the next one ... and the
next one ... and the next one ... all are pushing some strange ideas to
play with other programmers and make lot of work that is not at all
required! Let it be!!
Rename it and do what ever you like but stop ***playing*** with the
original Proj.4 source code, thanks!
Janne.
Kristian Evers kirjoitti 2016-11-03 16:40:
> Hello everybody,
> I want to direct your attention to the work Thomas Knudsen is doing on a new and more homogenous API for PROJ.4. Thomas presented his first ideas about a new API earlier this year when talk about transformation pipelines first started. Since then the initial pipeline pull request has been withdrawn and the changes needed to make transformation pipelines happen are broken into smaller more logical chunks. A new API being one of those smaller chunks. Before anyone gets their knickers in a twist, let me just stress the fact that this DOES NOT change the behavior of the old API (projects.h/proj_api.h), it merely adds a cleaner interface that will make usage of PROJ.4 a lot easier in the future.
> Thomas has already typed up a description of his work but until now it has only been available on the GitHub page. This is his introduction to the new API:
> The original proj API (defined in projects.h) has grown organically
> over the years, but it has also grown somewhat messy.
> The same has happened with the newer high level API (defined in
> proj_api.h): To support various historical objectives, proj_api.h
> contains a rather complex combination of conditional defines and
> typedefs. Probably for good (historical) reasons, which are not
> always evident from today's perspective.
> This is an evolving attempt at creating a re-rationalized API
> with primary design goals focused on sanitizing the namespaces.
> Hence, all symbols exposed are being moved to the pj_ namespace,
> while all data types are being moved to the PJ_ namespace.
> Please note that this API is *orthogonal* to  the previous APIs:
> Apart from some inclusion guards, projects.h and proj_api.h are not
> touched - if you do not include proj.h, the projects and proj_api
> APIs should work as they always have.
> A few implementation details:
> Apart from the namespacing efforts, I'm trying to eliminate three
> proj_api elements, which I have found especially confusing.
> FIRST and foremost, I try to avoid typedef'ing away pointer
> semantics. I agree that it can be occasionally useful, but I
> prefer having the pointer nature of function arguments being
> explicitly visible.
> Hence, projCtx has been replaced by PJ_CONTEXT *.
> SECOND, I try to eliminate cases of information hiding implemented
> by redefining data types to void pointers.
> I prefer using a combination of forward declarations and typedefs.
> Hence:
> typedef void *projCtx;
> Has been replaced by:
> struct projCtx_t;
> typedef struct projCtx_t PJ_CONTEXT;
> This makes it possible for the calling program to know that the
> PJ_CONTEXT data type exists, and handle pointers to that data type
> without having any idea about its internals.
> (obviously, in this example, struct projCtx_t should also be moved
> to struct pj_ctx some day...)
> THIRD, I try to eliminate implicit type punning. Hence this API
> introduces the OBSERVATION data type, for generic coordinate and
> ancillary data handling.
> It includes the PJ_SPATIOTEMPORAL and PJ_TRIPLET unions
> making it possible to make explicit the previously used
> "implicit type punning", where a XY is turned into a LP by
> re#defining both as UV, behind the back of the user.
> The bare essentials API presented here follows the PROJ.4
> convention of sailing the coordinate to be reprojected, up on
> the stack ("call by value"), and symmetrically returning the
> result on the stack. Although the OBSERVATION object is 4 times
> as large as the traditional XY and LP objects, timing results
> have shown the overhead to be very reasonable.
> See pj_proj_test.c for an example of how to use the API.
> The pull request is found at https://github.com/OSGeo/proj.4/pull/445 [1] and the example code can be found here: https://github.com/busstoptaktik/proj.4/blob/pipeline_plus_api/examples/pj_proj_test.c [2]
> Please share your thoughts on the new API that Thomas has been working on. There has already been some discussion about how to expose the thread-contexts of the PJ-objects. In the current incarnation they are somewhat hidden to the user compared the what's in proj_api.h. On top of that, Thomas and I have personally discussed the projFileAPI which does not seem to be used outside of PROJ.4 itself (at least nothing shows up on google, closed source we have no idea about). Is this something people actually need?
> /Kristian
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
MNS Support
NNS Master Navigator Software
Copyright (c) Sapper Oy
www.mnspoint.com [3]
Links:
[1] https://github.com/OSGeo/proj.4/pull/445
[2]
[3] http://www.mnspoint.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161114/05d8c8d9/attachment.html>
