[Proj] A re-rationalized API for PROJ.4
Roger Oberholtzer roger.oberholtzer at gmail.com
Mon Nov 14 05:45:18 PST 2016
+1 Mikael
On Mon, Nov 14, 2016 at 1:02 PM, Mikael Rittri <Mikael.Rittri at carmenta.com>
wrote:
> I just want to say that, although I personally will probably not bother to
> change to the new API, I have always found the traditional source code of
> Proj.4 difficult to read, and I am happy to see a new enthusiastic group of
> developers taking care of Proj.4.  The period of stagnation a few years ago
> was unfortunate.
> Mikael Rittri
> Carmenta
> Sweden
> <http://www.carmenta.com/>http://www.carmenta.com
> *From:* proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.
> maptools.org] *On Behalf Of *Kristian Evers
> *Sent:* Thursday, November 03, 2016 3:41 PM
> *To:* PROJ.4 and general Projections Discussions
> *Subject:* [Proj] A re-rationalized API for PROJ.4
> Hello everybody,
> I want to direct your attention to the work Thomas Knudsen is doing on a
> new and more homogenous API for PROJ.4. Thomas presented his first ideas
> about a new API earlier this year when talk about transformation pipelines
> first started. Since then the initial pipeline pull request has been
> withdrawn and the changes needed to make transformation pipelines happen
> are broken into smaller more logical chunks. A new API being one of those
> smaller chunks. Before anyone gets their knickers in a twist, let me just
> stress the fact that this DOES NOT change the behavior of the old API
> (projects.h/proj_api.h), it merely adds a cleaner interface that will make
> usage of PROJ.4 a lot easier in the future.
> Thomas has already typed up a description of his work but until now it has
> only been available on the GitHub page. This is his introduction to the new
> API:
> The original proj API (defined in projects.h) has grown organically
> over the years, but it has also grown somewhat messy.
> The same has happened with the newer high level API (defined in
> proj_api.h): To support various historical objectives, proj_api.h
> contains a rather complex combination of conditional defines and
> typedefs. Probably for good (historical) reasons, which are not
> always evident from today's perspective.
> This is an evolving attempt at creating a re-rationalized API
> with primary design goals focused on sanitizing the namespaces.
> Hence, all symbols exposed are being moved to the pj_ namespace,
> while all data types are being moved to the PJ_ namespace.
> Please note that this API is *orthogonal* to  the previous APIs:
> Apart from some inclusion guards, projects.h and proj_api.h are not
> touched - if you do not include proj.h, the projects and proj_api
> APIs should work as they always have.
> A few implementation details:
> Apart from the namespacing efforts, I'm trying to eliminate three
> proj_api elements, which I have found especially confusing.
> FIRST and foremost, I try to avoid typedef'ing away pointer
> semantics. I agree that it can be occasionally useful, but I
> prefer having the pointer nature of function arguments being
> explicitly visible.
> Hence, projCtx has been replaced by PJ_CONTEXT *.
> SECOND, I try to eliminate cases of information hiding implemented
> by redefining data types to void pointers.
> I prefer using a combination of forward declarations and typedefs.
> Hence:
>     typedef void *projCtx;
> Has been replaced by:
>     struct projCtx_t;
>     typedef struct projCtx_t PJ_CONTEXT;
> This makes it possible for the calling program to know that the
> PJ_CONTEXT data type exists, and handle pointers to that data type
> without having any idea about its internals.
> (obviously, in this example, struct projCtx_t should also be moved
> to struct pj_ctx some day...)
> THIRD, I try to eliminate implicit type punning. Hence this API
> introduces the OBSERVATION data type, for generic coordinate and
> ancillary data handling.
> It includes the PJ_SPATIOTEMPORAL and PJ_TRIPLET unions
> making it possible to make explicit the previously used
> "implicit type punning", where a XY is turned into a LP by
> re#defining both as UV, behind the back of the user.
> The bare essentials API presented here follows the PROJ.4
> convention of sailing the coordinate to be reprojected, up on
> the stack ("call by value"), and symmetrically returning the
> result on the stack. Although the OBSERVATION object is 4 times
> as large as the traditional XY and LP objects, timing results
> have shown the overhead to be very reasonable.
> See pj_proj_test.c for an example of how to use the API.
> The pull request is found at https://github.com/OSGeo/proj.4/pull/445 and
> the example code can be found here: https://github.com/
> busstoptaktik/proj.4/blob/pipeline_plus_api/examples/pj_proj_test.c
> Please share your thoughts on the new API that Thomas has been working on.
> There has already been some discussion about how to expose the
> thread-contexts of the PJ-objects. In the current incarnation they are
> somewhat hidden to the user compared the what’s in proj_api.h. On top of
> that, Thomas and I have personally discussed the projFileAPI which does not
> seem to be used outside of PROJ.4 itself (at least nothing shows up on
> google, closed source we have no idea about). Is this something people
> actually need?
> /Kristian
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Roger Oberholtzer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161114/e8fd30b4/attachment.html>
