[Proj] Differences across v4.8 and v4.9
Joaquim Luis jmfluis at gmail.com
Mon Aug 28 10:28:21 PDT 2017
>> The first one (between A1 and B1) is specially more troublesome because
>> is
>> the example provide in the cs2cs doc page
>> (http://proj4.org/apps/cs2cs.html) that agrees with 4.8.0 and not with
>> 4.9.2
>> Joaquim
>> proj
>> Rel. 4.8.0, 6 March 2012
>> A1
>> echo 45.25919444444 -111.5 | cs2cs +proj=latlong +datum=NAD83 +to
>> +proj=utm +zone=10  +datum=NAD27 -r
>> 1402285.99      5076292.42 -0.00
> I do get this result with proj 4.9.3 too (actually I get
> 1402285.98	5076292.42 -0.00,
> so a slight difference rounding), so I suspect your below 4.9.3 build
> has been made
> without unzipping first the grids at
> http://download.osgeo.org/proj/proj-datumgrid-1.6.zip
> into the nad/ directory
No I hadn't. I didn't know about those files. I build proj.4 from the
Github repo and thought it had all necessary files.
Now I also get
pj_apply_gridshift(): used Conterminous United States
but it still complains of not finding
pj_open_lib(ntv2_0.gsb): call
fopen(C:\programs\compa_libs\proj4_GIT\nad\ntv2_0.gsb) - failed
which is not in the proj-datumgrid-1.6.zip file
> You can check if grids are used with
> echo 45.25919444444 -111.5 | PROJ_DEBUG=ON cs2cs  +proj=latlong
> +datum=NAD83 +to  +proj=utm >+zone=10  +datum=NAD27 -r
> You should see towards the end something like
> NTv1 393x177: LL=(-142,40) UR=(-44,84)
> pj_open_lib(conus): call fopen([...]/share/proj/conus) - succeeded
>> A2
>> echo 4.897 52.371 | proj +proj=aeqd +ellps=WGS84 +units=m
>> 384923.72       5809986.50
> Not completely sure about that one when looking at history of
> https://github.com/OSGeo/proj.4/commits/master/src/PJ_aeqd.c
> Perhaps
> https://github.com/OSGeo/proj.4/commit/2d0acd7d61374a167f532cd2851f46f63d5e09a4
> or
> https://github.com/OSGeo/proj.4/commit/de8d6779aaabe0c46c06b9047bc6a6a978cc0758
>> A3
>> echo 4.897 52.371 | proj +proj=robin +ellps=WGS84 +units=m
>> 394576.51       5571243.64
> I suspect the difference comes from
> https://github.com/OSGeo/proj.4/commit/d856016ca1a178cc81c4474c0a6bbe78d106d012
> I agree the https://github.com/OSGeo/proj.4/blob/master/NEWS don't
> mention this case nor A2.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
