[Proj] Differences across v4.8 and v4.9
Kristian Evers
kreve at sdfe.dk
Mon Aug 28 11:45:23 PDT 2017
> Regarding the new API, ... I'm counting on Even because we are accessing
proj.4 via GDAL.
In that case, never mind. I just wanted to put it on your radar in case you were unaware and interacting directly with PROJ.4. I am sure the features we are working on will show up in GDAL as well at some point in the future.
/Kristian
-----Oprindelig meddelelse-----
Fra: Joaquim Luis [mailto:jmfluis at gmail.com]
Sendt: 28. august 2017 20:01
Til: Kristian Evers <kreve at sdfe.dk>
Emne: Re: SV: [Proj] Differences across v4.8 and v4.9
> In that case, are you aware that we are introducing a new API to PROJ.4
> with the next version (that will be released soon)?
> I would suggest you use the new API if you are if you haven't used
> PROJ.4 in your application previously.
Yes, I've been following the discussions and curious how it's going to be
implemented (I'm a Geophysicist who works in plate kinematics from time to
time, though on the scales of Ma for which Euler poles do not always
exactly agree with GPS ones).
proj.4 via GDAL.
More information about the Proj
