[Proj] EPSG v9.0 upgrade
Even Rouault
even.rouault at spatialys.com
Tue Jan 10 05:25:34 PST 2017
I've updated to the EPSG v9.0 database.
The relevant tickets are:
* libgeotiff: https://trac.osgeo.org/geotiff/ticket/83
* GDAL: https://trac.osgeo.org/gdal/ticket/6772
* proj.4: proj.4: https://github.com/OSGeo/proj.4/issues/477
* postgis: https://trac.osgeo.org/postgis/ticket/3684 (patch submitted)
Combined with that update, I've also applied datum shift overrides for EPSG:4149 (CH1903),
EPSG:3844 (Pulkovo 1942(58) / Stereo70 Romania), EPSG:31251,31252,31253 (MGI (Ferro) /
Austria), EPSG:2397/2398/2399 (Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 3,4,5), EPSG:
2065 (S-JTSK (Ferro) / Krovak).
Those were awaiting in various GDAL/libgeotif/proj tickets (*), and were not doable until now
for most of them, since there was no possibility of defining datum shift overrides specific to
projected coordinate systems, before the changes done in https://trac.osgeo.org/geotiff/
changeset/2747 and
https://trac.osgeo.org/gdal/changeset/37080
Even
(*) From libgeotiff ChangeLog:
2017-01-10 Even Rouault <even dot rouault at spatialys dot com>
* csv/datum_shift_pref.csv: add overrides for PCS 2065
Fixes https://trac.osgeo.org/gdal/ticket/4762 and
https://github.com/OSGeo/proj.4/issues/185
* csv/datum_shift_pref.csv: add overrides for PCS 2397/2398/2399
Fixes https://github.com/OSGeo/proj.4/issues/235
* csv/datum_shift_pref.csv: add overrides for PCS 31251,31252,31253
(MGI (Ferro) / Austria)
Fixes https://github.com/OSGeo/proj.4/issues/254
* csv/build_pcs.py, csv/datum_shift_pref.csv: add mechanism to define
TOWGS84 parameters per PCS (instead of only relying on the TOWGS84
parameters of the underlying GCS).
Add override for EPSG:3844 ("Pulkovo 1942(58) / Stereo70" Romania)
Fixes https://trac.osgeo.org/geotiff/ticket/52
* csv/datum_shift_pref.csv: add override for CH1903 (EPSG:4149)
Fixes https://trac.osgeo.org/geotiff/ticket/73
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170110/80edee37/attachment.html>
More information about the Proj
