[Proj] Coming releases of PROJ.4
Even Rouault
even.rouault at spatialys.com
Fri Jun 23 02:05:39 PDT 2017
> The problem is that pj_inv() hard fails when an inverse is attempted and
> none exists, so we need protection to avoid crashing the R session:
For the record, this issue has been fixed in proj 4.9.3 per :
https://github.com/OSGeo/proj.4/commit/757a2c8f946faccf9d094d76cb79e6ebe0006564#diff-f0c3df1eafd91a86f6cd9cf68cc306ddR23
pj_inv will now return (HUGE_VAL,HUGE_VAL) if the inverse doesn't exist.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170623/884fdc37/attachment.html>
More information about the Proj
