[Proj] +towgs84 approximation error
Jochem
jochem.lesparre at kadaster.nl
Wed Mar 22 17:48:55 PDT 2017
Hi Martin,
WGS84 is just a hub for many users. I will transform data from frame A via
WGS84 to frame B. The transformation from A to B should have 1 mm (not 0.1
mm) accuracy for me, since the coordinates are of 1 cm accuracy.
Moreover, 7 parameter transformations are not always stochastic, e.g. the
transformation between the Dutch national grid and ETRS89 (=WGS84 +/- 1 m)
is by definition exact since the Dutch national grid is defined as the
transformation from ETRS89.
Furthermore, world wide geodetic positional accuracy in ITRF (=WGS84 +/-
0.0001 m) is possible well below the accuracy of the 4 cm error I am
experiencing.
I think these are 3 reasons why the approximation is not good enough and
should be improved.
Regards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313761.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
