[Proj] +towgs84 approximation error
Jochem
jochem.lesparre at kadaster.nl
Wed Mar 22 19:37:49 PDT 2017
Hi Stefanos,
You are still completely misunderstanding my problem. The responsible agency
already did these measurements. And the measurements are ok. They also
computed the 7 parameters. These are ok too. I checked the least-squares
adjustment. The problem is that the Proj.4 formulas are wrong. Wrong in the
sense that they give different results from transformation with other
software. I used several software packages and the differences between them
were 0.1 to a few mm. The only one that was 4 cm different was Proj.4.
However I don't want to use one of the other software packages as these can
only transform points and not vector maps like QGIS.
Ragards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313778.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
