[Proj] +towgs84 approximation error
Thomas Knudsen knudsen.thomas at gmail.com
Thu Mar 23 07:42:08 PDT 2017
Hi Jochen,
A pull request is the way you contribute code to (most) open source
projects.
A good starting point will be to first take a look at the Proj.4 Github
page over
at https://github.com/OSGeo/proj.4 - then continue to learn about the GitHub
workflow from https://guides.github.com/introduction/flow/
...and then jump in at the deep end by opening a Github user account,
cloning Proj.4 to your own account and start learning git.
If you are new to distributed version control systems, git will be a big
mouthful,
but it is worth learning.
/Thomas
2017-03-23 13:58 GMT+01:00 Jochem <jochem.lesparre at kadaster.nl>:
> Hi Thomas,
> You are right. Probably there are users that would want to still be able to
> use the approximate formulas. I think the default should be no
> approximation, but maybe the other way around is better for backward
> compatibility.
> What is a pull request? (I'm new here.)
> Regards, Jochem
> View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-
> approximation-error-tp5313738p5313857.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170323/7199a2fb/attachment.html>
